Reflektometar
Autor OuttaControlCRO, 10.12.2022. u 23:32:14 sati
Evo da ne spamam onu temu za vakum komoru, slozio sam program i pospojio sve, uspio sam natjerati preciznost na 0.2% ali samo u uvjetima maximalne osvjetljenosti, ostalo ne znam testirat, a sve je skalamerija.
23:23:11.088 -> Lux while laser is off
23:23:11.088 -> 1
23:23:18.359 -> Lux while laser is on
23:23:18.359 -> 43720
23:23:18.359 -> Press button to start mesuring
23:23:30.619 -> Lux = 43686 Percentage = 99.92
23:23:42.875 -> Lux = 43664 Percentage = 99.87
23:23:55.130 -> Lux = 43671 Percentage = 99.89
23:24:07.387 -> Lux = 43645 Percentage = 99.83
23:24:19.635 -> Lux = 43633 Percentage = 99.80
23:24:31.899 -> Lux = 43653 Percentage = 99.85
23:24:44.155 -> Lux = 43641 Percentage = 99.82
23:24:56.387 -> Lux = 43624 Percentage = 99.78
23:25:08.647 -> Lux = 43653 Percentage = 99.85
23:25:20.902 -> Lux = 43657 Percentage = 99.86
23:25:33.153 -> Lux = 43652 Percentage = 99.84
23:25:45.423 -> Lux = 43631 Percentage = 99.80
23:25:57.656 -> Lux = 43630 Percentage = 99.79
23:26:09.937 -> Lux = 43641 Percentage = 99.82
23:26:22.163 -> Lux = 43636 Percentage = 99.81
23:26:34.417 -> Lux = 43650 Percentage = 99.84
23:26:46.690 -> Lux = 43646 Percentage = 99.83
23:26:58.949 -> Lux = 43654 Percentage = 99.85
23:27:11.180 -> Lux = 43644 Percentage = 99.83
23:27:23.431 -> Lux = 43646 Percentage = 99.83
23:27:35.698 -> Lux = 43632 Percentage = 99.80
23:27:47.960 -> Lux = 43647 Percentage = 99.83
23:28:00.222 -> Lux = 43647 Percentage = 99.83
23:28:12.460 -> Lux = 43632 Percentage = 99.80
23:28:24.713 -> Lux = 43653 Percentage = 99.85
23:28:36.957 -> Lux = 43659 Percentage = 99.86
23:28:49.230 -> Lux = 43672 Percentage = 99.89
23:29:01.489 -> Lux = 43640 Percentage = 99.82
23:29:13.750 -> Lux = 43654 Percentage = 99.85
23:29:25.982 -> Lux = 43679 Percentage = 99.91
23:29:38.241 -> Lux = 43683 Percentage = 99.92
23:29:50.483 -> Lux = 43685 Percentage = 99.92
23:30:02.760 -> Lux = 43726 Percentage = 100.01
23:30:15.000 -> Lux = 43709 Percentage = 99.97
23:30:27.245 -> Lux = 43704 Percentage = 99.96
23:30:39.516 -> Lux = 43696 Percentage = 99.95
23:30:51.760 -> Lux = 43717 Percentage = 99.99
23:31:04.034 -> Lux = 43722 Percentage = 100.00
23:31:16.281 -> Lux = 43719 Percentage = 100.00
23:31:28.535 -> Lux = 43708 Percentage = 99.97
23:31:40.785 -> Lux = 43725 Percentage = 100.01
23:31:53.033 -> Lux = 43720 Percentage = 100.00
23:32:05.293 -> Lux = 43716 Percentage = 99.99
23:32:17.548 -> Lux = 43716 Percentage = 99.99
23:32:29.796 -> Lux = 43743 Percentage = 100.05
23:32:42.077 -> Lux = 43729 Percentage = 100.02
23:32:54.325 -> Lux = 43752 Percentage = 100.07
23:33:06.575 -> Lux = 43736 Percentage = 100.04
Test iz ruke:
Obično ogledalo
23:44:32.805 -> Lux = 37709 Percentage = 86.25
23:44:45.056 -> Lux = 37294 Percentage = 85.30
23
Disk od nehrđajućeg čelika
23:41:41.267 -> Lux = 23129 Percentage = 52.90
Obicno ogledalo mora biti 98% (srebro).
#3
Onda mozda ne radi  *zubo*, iako ali dobra teleskopska stakla nisu inace oko 97%, kako onda ovo iza stakla moze bit 98?
Ja sam ovo. nasa
https://www.engineeringtoolbox.com/light-material-reflecting-factor-d_1842.html
Jesi to testirao sa odbljeskom od papira ili direkt laser u senzor?
-SW 105/500 akromat
-Canon 1300D
-ZWO ASI-120 MC
Direkt laser u senzor, teško mi i tako naciljat  *zubo* neman neku skalameriju da to drzi na mistu sve
I ispravak netočnog navoda ovo nisu Luxi nego raw sensor data, samo za visible spectrum luxi se racunaju sa posebnom funkcijom koja uracunava i IR spektar
oke, probat ću ja dovršiti dizjan ovih dana pa stavim printati djelove :)
-SW 105/500 akromat
-Canon 1300D
-ZWO ASI-120 MC
#7
Nista ja cu dovrsit program kako je pa ti poslat na testiranje mislim  da sam. pogodio maksimalni dinamički raspon.
Dalo bi se unaprijediti program da možeš sam birati postavke preko nekog web sucelja, ali nemam trenutno vremena za to.
Trenutno ce raditi ovako
1. Uredjaj se ukljuci u USB, ili 12V power adapter (moja preporuka jer je microUSB port vrlo osjetljiv i lako otpadne)
2. Na ekranu se pojavi "Click to start calibration"za mirenje kad je ugasen laser, nakon 2 sekunde od klika se očita vrijednost i spremi. - ovo sam konfiurirao da uhvati 1 lux, il koja je jedinica u jako slabom osvjetljenju
3. Onda se pojavi "Click to mesure when laser is on", dakle maksimalna vrijednost, pali se laser i nakon 2 sekunde od klika ide mjerenje max vrijednosti. Kad laser direkt cilja u senzor to je neki 50000 jedinica. Max je 65000 i povecanjem gaina, il expozicije udaramo u taj max.
I tad krece defautl loop, kad se pritisne tipka, laser se pali, nakon 2s se ocita vrijednost.
I tu cu ubacit trik, double click na botun, pali "contnious mode" u kojem laser stalno radi i vrijednost se očitava svaku sekundu ili pola sekunde. Ponovni single klik gasi taj contnous mode i vraća se u defaultni botun mod, moram to jos malo sklepat.
Uz to za dodatne detalje(IR, stvarni luxi, raw data) treba se spojiti  na SerialMonitor Baud 115200
Relej za laser je napravljen na principu dry contacta, te se moze prispojit na bilokoje napajanje, neovisno o pločici, ja sam spojio na pločicu na 3v3
Malo tehničkih detalja, nemam kad crtat shemu.
IO12 je spojen na botun. - ljubičasta
IO16 je spojen relej. - ljubičasta
na 5V je spojeno napajanje releja, i ekran -narančasta
na 3v3 je spojen LUX senzor i laser. Lux može i na 5, laser je prejak na 5. - žuta
SCL - ide na display i lux senzor  - plava
SDA - ide na display i lux senzor - zelena
i uzemljenje je Siva/Bila, ide na sve :D
E super hvala! Jel bi ovo čudo radilo na Arduino Nano kojim slučajem? Jer ova pločica je poprilično velika pa neće stati unutra u kutiju a bilo bi šteta mjenjati ovaj dizajn da bude još veći...
-SW 105/500 akromat
-Canon 1300D
-ZWO ASI-120 MC
Vidim da podrzava scl i sda, tako da ne vidim zašto nebi  radilo, ali nemam niti sam ikad koristio taj board, trebalo bi namjestiti pinove i to je to. Kad dovršim program stavit cu ga na github pa ce bilo ko moc sebi složit
-SW 105/500 akromat
-Canon 1300D
-ZWO ASI-120 MC
#11
Gotov!
kod je tu:
https://github.com/OuttaControlCRO/reflectometer
A na pm ti se javim da mi das adresu, ili tisak, za slanje djelova
Ovo je moj nered, nadam se da ce MrWorf to dovest u red da i izgleda fino
Odlično, hvala! Kad poprintam sve i složim, stavim fotke tu, kao i rezultate testiranja!  *hopla* *šešir*
-SW 105/500 akromat
-Canon 1300D
-ZWO ASI-120 MC
