Eruptivna nova T CrB
Autor Teofil, 21.03.2024. u 00:41:47 sati
Prebacio sam ovdje temu o zvijezdi T CrB koja će eksplodirati idućih dana (mjeseci ?) u zviježđu Sjeverne krune, a mogla bi povećati prividni sjaj čak do +2 magnitude.
To je "ponavljajuća nova". Snimio sam ju 25. kolovoza 2021. kad joj je prividni sjaj bio približno +10.5 magnitude (isječak izvornog formata 6000x4000px).
Više:
https://hr.wikipedia.org/wiki/T_Coronae_Borealis
https://www.aavso.org/news/t-crb-pre-eruption-dip
https://www.earth.com/news/rare-star-explosion-will-be-visible-for-a-week/
Citat:
"On 20 April 2016, the Sky and Telescope website reported a sustained brightening since February 2015 from magnitude 10.5 to about 9.2. A similar event was reported in 1938, followed by another outburst in 1946. By June 2018, the star had dimmed slightly but still remained at an unusually high level of activity. In March or April 2023, it dimmed to magnitude 12.3. A similar dimming occurred in the year before the 1945 outburst, indicating that it will likely erupt between March and September 2024."
Objekt: Eruptivna nova T CrB,  V= +10.5 mag
Vrijeme: 25. kolovoza 2021, 20:48 UT+2
Objektiv: Nikon 70-210mm @ 70mm f/4
DSLR: Nikon D5200, ISO 800, 9x30s, dark x2
Montaža: CG-5 AS-GT (praćenje)
Obrada: DSS, GIMP
Mjesto: Virovitica, Hrvatska - Croatia
Recurrent nova T CrB - Explosion coming soon by Zlatko F. Kovacevic, on Flickr
Namjeravam paziti na T CrB iako je kod mene nisko (~25°), i bas u smjeru city-a (gdje je LP najjaci) kad kulminira..
Citat: bojan  u 21.03.2024. u 01:10:09 satiNamjeravam paziti na T CrB iako je kod mene nisko (~25°), i bas u smjeru city-a (gdje je LP najjaci) kad kulminira..
Ako je 10-12 magnitude, to ne bi trebao biti nikakav problem.
Citat: Astrobobo  u 21.03.2024. u 10:15:29 satiAko je 10-12 magnitude, to ne bi trebao biti nikakav problem.
Yep, nije problem za fotometriju.
Vise je problem sto nisam svaki dan (noc) na Mt Pleasant, a iz Melb imam dvece u tom smjeru. Bumo vidli...
Takodjer, LP je veliki problem za moj spektrometar (koji je baziran na Star Analyzer 100 lines/mm), slika spektra se superponira na svjetli fon neba.. i ako je sama zvijezda malog sjaja, oa kad se to razmaze na svjetlu pozadinu.. nista ne ostane za spektar.
Sama slikica Nove je OK ali spektar.. to bi zbilja bilo bilo fora.
Radio sam na boljem spektrometru (kod kojeg to ne bi bio problem, slika zvijezde se fokusira na opticki kabel, odakle svjetlo ide na resetku) ali ga nisam zavrsio zbog nedostatka vremena.. mozda ce ovaj dogadjaj biti dovoljan poticaj za mene da to zavrsim ;-) )
Snimka T CrB prije eksplozije pomoću teleskopa.
Aktualni sjaj i ranije:
https://app.aavso.org/webobs/results/?star=T+CrB&num_results=25&obs_types=all&page=1
Vrijeme: 2. ožujka 2024. 21:48 UT
Teleskop: Celestron SC 203/2032mm @ f/6.3
DSLR: Nikon D5200, ISO 1600, 10sx4
Obrada: Sequator, GIMP, isječak cca 29' x 21'
23. lipnja pokraj T CrB proći će planetoid 2 Palas (Palada).
https://www.zvjezdarnica.com/astroforum/index.php?topic=4779.0
Vremenske prilike idućih dana su nesigurne pa sam sinoć snimao ovaj par usprkos atmosferi s mnogo pijeska iz Sahare, visinskim oblacima i mjesečini.
Vrijeme: 20. lipnja 2024.  21:04-21:22 UT
Objektiv: Nikon 70-210mm @ 210mm f/5.6
DSLR: Nikon D5200, ISO 1600, 15s x 24
Planetoid 2 Palas i zvijezda T CrB by Zlatko F. Kovacevic, on Flickr
Nažalost nisu se ispunile naše želje i očekivanja -zvijezda TCrB u prethodnim mjesecima nije naglo povećala sjaj sa +10 prividne magnitude na + 3 magnitudu.
Od približno 20. prosinca do 5. travnja TCrB bit će na nebu prividno u blizini Sunca i ako se tada dogodi erupcija fotkanje će biti sanak pusti.
Mislim da je netko Teofilu hakirao account... jer se kompletno zviježđe već sad vidi par sati prije izlaska Sunca?
Arktur se već jasno vidi krajem siječnja oko 23h na istoku
Citat: Šegi  u 29.11.2024. u 16:53:24 satiMislim da je netko Teofilu hakirao account... jer se kompletno zviježđe već sad vidi par sati prije izlaska Sunca?
Teofilu nije netko hakirao account.
U Stellariumu sam vjerojatno "pobrkao lončiće" i napisao neistinu.  *he*
Prošao rujan 2024. i prolazi 2024. bez najavljene erupcije... Neka veća oscilacija?
https://apps.aavso.org/webobs/results/?star=000-BBW-825&num_results=200
Pa ne vidim ja tu ništa čudno.
Treba uzeti u obzir da je zbog položaja zvijezde sada manji broj mjerenja pa će "lošija" mjerenja imati veći utjecaj.
Ima li novih saznanja oko T CrB?
