Autor Tema: Betelgez smanjuje sjaj  (Posjeta: 6149 vremena)
  • Postova: 1182
« u: 25.12.2019. u 10:03:37 sati »
Tek sam sad naletio, ali već par dana se priča o tome kako je Betelgez smanjila sjaj: https://earthsky.org/space/betelgeuse-fainting-probably-not-about-to-explode
Na žalost ne mogu naći puno informacija osim ovdje https://twitter.com/astronomerstel/status/1203533044373741573 i u grafu u attachu.
  • Hiperion
  • Postova: 1201
Odg: Betelgez smanjuje sjaj
« Odgovori #1 u: 25.12.2019. u 10:31:37 sati »
Na AAVSO se može generirati krivulja sjaja, vidi se trend pada sjaja. V filter jako lijepo to pokazuje, pad s 0.6 na 1.3 magnitude, dok vizualne procjene više skakuću.
https://www.aavso.org/LCGv2/static.htm?DateFormat=Calendar&RequestedBands=V,Vis,Green&Grid=true&view=api.delim&ident=Betelgeuse&fromjd=2458728&tojd=2458842.994&delimiter=@@@
  • Enkelad
  • Postova: 1435
« Odgovori #2 u: 25.12.2019. u 13:02:06 sati »
Kod Zorkića je objašnjeno zašto se to događa. To je periodična pojava.
Citat:
Betelgez prolazi kroz složene kvaziperiodične promene sjaja pri čemu je dominantan period od približno 420 +/-15 dana. Takođe, zabeleženi su i dugoperiodične promene (ciklusi u trajanju 5 do 6 godina) kao i kraći (100 do 180 dana) sa manjim amplitudama promene sjaja.
Izvor: Updates on the "Fainting" of Betelgeuse
  • Postova: 1182
« Odgovori #3 u: 25.12.2019. u 15:39:39 sati »
Pa evo:
The current faintness of Betelgeuse appears to arise from the coincidence of the star being near the minimum light of the ~5.9-yr light-cycle as well as near, the deeper than usual, minimum of the ~425-d period. We plan to continue to monitor the star. If the star continues to follow above periods, light minimum should occur soon. But this needs to be checked. This continues to be an opportune time to carry out complementary measures of Betelgeuse while it is in its current low state and is unusually cool and faint.
Offline Zeleni_Zub
  • Postova: 303
« Odgovori #4 u: 26.12.2019. u 23:33:50 sati »
Evo i jos jedan clanak
https://www.forbes.com/sites/startswithabang/2019/12/25/is-betelgeuse-about-to-explode/?fbclid=IwAR1rNKiNS0M5NWZ8WeAamFW7QIu64mRMCVGQ-6BCNFouMH2JyIXF0aySYpU#3190b4e347bf
A bilo bi interesantno  *da*
Da li bi bilo kakvih stetnih efekata kada bi se posmatrao kroz teleskop bas u trenutku kad odluci da se raznese?
Teleskop: SW 150/750 EQ3
Dvogled: Made in China 7x50
Offline Arkturus
  • Postova: 309
« Odgovori #5 u: 27.12.2019. u 09:01:39 sati »
Naravno da bi.
Oko će ti biti naviknuto na tamu i odjednom ćeš u okularu imati „Mjesec“. Trgnut ćeš glavu i opaliti curu koja je iza tebe. Pri tom ćeš nogom zapeti za tripod, prevrnuti teleskop koji će pasti na kašetu piva do njega. Tvoj frend, koji se radovao pijači, pošizit će, „goni se u p...., koji k... radiš“, cura će reći „koji nespretni majmun“, pivo će se razliti po cesti, naići će šleper koji će proklizati i prijeći preko teleskopa, a prikolicom će odnijeti tvoj auto. Vozač šlepera će skinuti slušalice i zakočiti tako naglo da će od cvileži kočnica popucati stakla na dalekozoru, koji ti je još jedini ostao cijeli od opreme.
Na kraju će te kriminalistička policija pokupiti kao izbjeglicu jer ti je u padu novčanik s dokumentima odletio u žbunje i postaviti će posebnu rasvjetu na promatralište jer je očito da je taj punkt uz cestu nedovoljno osvijetljen.
Offline Zeleni_Zub
  • Postova: 303
« Odgovori #6 u: 27.12.2019. u 15:36:42 sati »
*rola* *rola*
Znaci ubuduce Betelgez posmatrati solo, sjedeći sa ploskom rakije u ruci na njivi sto dalje od granice  *rofl*
Offline MrWorf
  • Postova: 656
  • To ti je tak!
« Odgovori #7 u: 27.12.2019. u 15:44:22 sati »
Hahahah :D
-SW 105/500 akromat
-Canon 1300D
-ZWO ASI-120 MC
Offline Dag
  • Postova: 417
  • čovjek iz budućnosti
    • fotograf
« Odgovori #8 u: 27.12.2019. u 18:34:00 sati »
Naravno da bi.
Prestani koristit opijate
Offline Šegi
  • Postova: 203
« Odgovori #9 u: 27.12.2019. u 21:40:22 sati »
Ajde, barem nešto...
  • Arlecchino dello Cosmo
  • Postova: 1089
« Odgovori #10 u: 27.12.2019. u 23:08:48 sati »
  • Hiperion
  • Postova: 1201
« Odgovori #11 u: 31.12.2019. u 05:32:33 sati »
Sinoć sam se zagledao u Betelgez.
Sjajniji je od Belatrix, sjajniji od Poluksa, ali tamniji od Kastora. Rekao bih da je po sjaju na 2/3 puta od Kastora prema Poluksu.
To bi bilo negdje oko m=1.4
Offline Arkturus
  • Postova: 309
« Odgovori #12 u: 31.12.2019. u 09:04:16 sati »
Misliš obratno (Polux je sjajnini od Kastora).
Ako nije i Polux izgubio sjaj. *zubko*
Gledo sam i ja neku večer kad sam išo pogledat komet i moja procjena je identična.
  • Hiperion
  • Postova: 1201
« Odgovori #13 u: 31.12.2019. u 09:06:19 sati »
 *he*
Poslušat ću ovaj savjet
BTW: Poluks je Alfa Blizanaca, unatoč manjem sjaju. Možda je prije 2500 god bio sjajniji član para.
Offline Arkturus
  • Postova: 309
« Odgovori #14 u: 31.12.2019. u 09:12:38 sati »
Sigurno.
To je jedna stara priča koja govori baš to da je Kastor nekad (u staroj Grčkoj) bio sjajniji.
Ja bi dodao da je sve došlo na mjesto jer ipak je Poluks božanskog porijekla u mitologiji, a Kastor nije, pa je i red da su bogovi ispravili tu grešku.
