Starship
Autor Arkturus, 08.12.2020. u 11:56:33 sati
c2
Razbio se ko p...  :-(
I go unseen.
All shall be revealed.
A ništa se nije vidjelo od silne magluštine. Samo se čuo prasak i to je to. Tu i tamo bi pao koji komadić oplate. *šok*
Arkturus
Sad sam prvi puta vidio snimku samih sapnica motora tijekom leta i ne znam jel to uobičajeno, ali čini mi se da se oni plamičci oko motora ne bi trebali pojavljivati. Tu je možda nešto pregorilo pa kad su se pri slijetanju upalili motori... buuuuum. *jok*
https://www.youtube.com/watch?v=TihyY6s84Q4
Motori su usisali maglu, smočila im se svijećica i...
Sad za ozbač. Elon je rekao da su tokom cijelog leta imali problema s motorima, prenizak tlak u komori za izgaranje.
c2
#64
Počelo je sastavljanje Starship SN15.
SN12-SN14 neće letjeti jer su zastarjeli (SN15 ima preko 100 izmjena).
Mudro su izbjegli baksuznu 13.  *zubko*
I go unseen.
Arkturus
Evo Musk potvrđuje:
"As Spaceflight Now reports, Musk replied to a question on Twitter asking if the investigation had returned any results. In his reply, the SpaceX founder revealed that everything looked good up to and including the free-fall stages of the test flight, but things went south when the landing burn began to fire.
"Ascent phase, transition to horizontal, & control during free fall were good," Musk tweeted. "A (relatively) small CH4 leak led to fire on engine 2 & fried part of the avionics, causing hard start attempting landing burn in CH4 turbopump. This is getting fixed 6 ways to Sunday."
So, a gas leak and subsequent fire messed up some vital components and when the spacecraft's engines fired back up to aid in a soft landing it triggered the explosion. All we saw from the video feed was a massive shower of rocket debris falling through the fog, so it's nice to hear that the company seems to have a pretty good idea of what caused the failure.
Dakle, od turbopumpe su napravili komoru za izgaranje  *zubo*
Čudi me što na Starshipu ne naprave istu foru kao Rocket Labs na Electronu. Naime, mogli bi na 2-3 motora (sada su to jedini motori) staviti pogon pumpi na struju. Time bi dobili bolju kontrolu potiska i veću pouzdanost.
c2
Starship SN15 bi trebao poletjeti za cca 6 sati.  *ritmika*
I go unseen.
c2
SN15
novi pokušaj za 11 minuta  *ritmika*
I go unseen.
Još manje od 2 minute. *hopla*
I tak, spustio se uspješno i opet je u požaru. *šok*
woooo  *pljesk* *pljesk* *pljesk*
Kako je prelijep prizor vidjeti da je lijepo sletio  *pljesk*
Valjda rijese i vatricu
lonewolf21
Moje je mišljenje da će i u buduće imati problema sa požarom prilikom slijetanja osim ako nešta ne promijene u samom dizajnu.
Motori su preduboko u tijelu i prilikom slijetanja većina plinova nema kud izaći i onda velikoj temperaturi izlaže sva ta crijeva i ventile koji se raspadaju i izazovu požar.
Ovaj puta su ga uspješno ugasili, idući puta tko zna.  *jok*
45°13'01" N 17°44'28" E
