Autor Tema: Trik za crveni ekran na iPhone-u  (Posjeta: 687 vremena)
  • Postova: 1089
« u: 28.07.2018. u 10:56:02 sati »
Naletio sam na ovaj trik u jednoj astro grupi na FB, pa evo šaljem ovdje da vidite, zbilja je korisno. Iako ima aplikacija koje namještaju da ekran bude skroz crven, ovo je zgodno jer se može namjestiti shortcut na home gumb i ekran se zacrveni kad god hoćete.
Prenijeti ću cijeli citat koji je na engleskom:
Citat:
For those of you with an iOS device, here's a nifty trick I figured out how to make your screen red for those nights we spend out observing/imaging:
1. Go to Settings > General > Accessibility > Display Accommodations > Color Filters
2. Turn Color Filters ON
3. Scroll down and set Intensity to Max
4. Set Hue to either Minimum or Maximum. Both are red.
5. Turn Color Filters OFF
6. Go back to Accessibility and scroll all the way to the bottom.
7. Enter "Accessibility Shortcut" and check Color Filters.
You will now enable a red filter for your iOS device whenever you triple-click your home button (side button for iPhone X) quickly.
There's also a free app for Mac OSX called RedScreen that will do the same thing for your computer if you happen to be running a Mac: https://www.macupdate.com/app/mac/33578/redscreen
I haven't tested it but this Windows app should do the same: http://knightware.biz/knightvision/knightvision.htm
Offline bojan
  • Kalisto
  • Postova: 553
Odg: Trik za crveni ekran na iPhone-u
« Odgovori #1 u: 28.07.2018. u 21:03:26 sati »
Ili ga zamotas u crvani celofan  ;-)
  • Postova: 1089
« Odgovori #2 u: 29.07.2018. u 02:06:20 sati »
Joj što volim ove mudre prijedloge  *zubo* S koliko klikova odmotaš taj celofan?  *kokice*
Offline bojan
  • Kalisto
  • Postova: 553
« Odgovori #3 u: 29.07.2018. u 05:08:49 sati »
Niti jednim  *zubo*
Offline MelissaRycroft
  • Mjesečar
  • Postova: 1
« Odgovori #4 u: 08.07.2019. u 12:54:43 sati »
  • Postova: 1089
« Odgovori #5 u: 08.07.2019. u 19:33:56 sati »
Tko si ti i šta oćeš?
Offline Jed2i
  • Postova: 364
« Odgovori #6 u: 11.07.2019. u 14:05:51 sati »
Pa on popravlja taj tvoj crveni ekran! :D
Offline veljac
  • Postova: 230
« Odgovori #7 u: 13.07.2019. u 20:25:11 sati »
Primjer kako i najnedužniji savjeti mogu otići way off wrong  *zubo*
T: Maksutov 127, SW ED 80
M: AZ-EQ5, Nexstar SLT
K: Qhy8c,  ASI120MC
F: Canon M10, 15-45 mm
Offline ivo555
  • Postova: 362
  • Došao greškom i ostao
    • Flickr profil
« Odgovori #8 u: 14.07.2019. u 16:10:44 sati »
Bobo, predaj se  *zubko*
Esprit 80 F5, F4.25, Lacerta 72/432 ED
Samyang 135 T2.2
Zwo Asi183mm pro
Nikon D5300 H-alpha mod
Astrotrac TT320X-AG, Eq3
https://www.flickr.com/photos/107047074@N02/
  • Postova: 1089
« Odgovori #9 u: 14.07.2019. u 16:42:53 sati »
Šta sad TI oćeš*  *zubo*
