GraXpert4PixInsight
Autor Neven, 25.11.2023. u 12:35:57 sati
PixGraXpert - Graxpert AI iz Pixinsight-a.
Autor: Joel
Web: https://www.deepskyforge.com/
Cijena: Free
Link: https://github.com/DeepSkyForge/GraXpertSuite4PixInsight
Repo: All-in-one : https://pixinsight.deepskyforge.com/update/graxpert/ ili Suite: https://pixinsight.deepskyforge.com/update/graxpert-suite
Dokumentacija: https://drive.google.com/file/d/1QwktsUiQlAE31NWG4oUrJdsKGmbAIhmk/view
Još jedna stand alone skripta za korištenje Graxpert AI-a unutar Pixinisght-a.
Stand alone...bez prijatelja *baj*
Joel
Hi all,
Last version of my script is now availavle on GitHub:
https://github.com/AstroDeepSky/GraXpert4PixInsight
Enjoy!
#3
Citat: Joel  u 12.12.2023. u 08:10:44 satiHi all,
Enjoy!
I cannot believe it. I just wanted to post the new Github link (I followed the 'Command line needs few enhancements #95' thread  :-) ), I really didn't think the original author would step in.  *gore*
Thank you for this Script, I personally prefer your script, it has more options.
Good thing I've seen it on PI forum before they removed it.  *jok*
Joel
#4
Thanks @Neven!
Hi all,
I just released a new version of GraXpert4PixInsight (new name):
https://github.com/AstroDeepSky/GraXpert4PixInsight/
Do not hesitate to put a star on GitHub and share with your freinds!
Enjoy...
Ja nisam uspio shvatiti kako se instalira GraXpert za PI. Piše "Copy GraXpert4PixInsight src and rsc folders in PixInsight folder", ali u downloadu nema nikakvih foldera, samo .exe fajl koji otvara solo GraXpert.
Citat: Astrobobo  u 30.12.2023. u 07:01:01 satiJa nisam uspio shvatiti kako se instalira GraXpert za PI. Piše "Copy GraXpert4PixInsight src and rsc folders in PixInsight folder", ali u downloadu nema nikakvih foldera, samo .exe fajl koji otvara solo GraXpert.
GraXpert skineš u bilo koji folder, to je program za sebe.
Graxpert4Pixinsght je skripta koju instaliraš ovako:
GraXpert.js skopiraš u 'c:\Program Files\PixInsight\src\scripts\GraXpert\'
GraXpert.svg skopiraš u c:\Program Files\PixInsight\rsc\icons\script\GraXpert\
Otvoriš PI odeš na Scripts/Feature Scripts pa na Add pa u folder C:\Program Files\PixInsight\src\scripts\GraXpert i klikneš na GraXpert.js
Nakon toga skripa je na Scripts/Utilities/GraXpert
Kad ju otvoriš stisneš samo na ikonu skroz dolje u desnom kutu da joj pokažeš folder gdje si skinuo GraXpert app.
A gdje nađem GraXpert.js i GraXpert.svg kad s linka mogu skinuti samo GraXpert.exe?
Citat: Astrobobo  u 31.12.2023. u 05:55:55 satiA gdje nađem GraXpert.js i GraXpert.svg kad s linka mogu skinuti samo GraXpert.exe?
Odeš na https://github.com/AstroDeepSky/GraXpert4PixInsight pa desno imaš releases i skineš verziju Vega star (v0.0.7) Source code(zip) i u zip-u su ti ta 2 fajla.
Joel
For your information, GraXpert team did a PreRelease v2.1.1 yesterday.
https://github.com/Steffenhir/GraXpert/releases/tag/2.1.1
This version bring improvements in performances and gives the possibility to extract background model.
You can use this version with GraXpert4PixInsight version v1.0.0-beta.3.
https://github.com/AstroDeepSky/GraXpert4PixInsight/releases/tag/v1.0.0-beta.3
You can get more information on GraXpert4PixInsight here:
Support available here:
https://github.com/AstroDeepSky/GraXpert4PixInsight/issues
Enjoy!
Citat: Joel  u 31.12.2023. u 10:17:42 satiFor your information, GraXpert team did a PreRelease v2.1.1 yesterday.
Enjoy!
It works great. Finally a faster version without that damn splash screen.
Thanks Joel.
G4P Pre-release za GraXpert 2.1.1 Pre-release.
Super napreduje ova skripta. Stvarno mi se sve više sviđa.
Joel
Hi all,
GraXpert v2.2.0 is released.
It works fine with GraXpert4PixInsight v1.0.0 which is also officially released.
I was working on GraXpert v1.1.0 allowing users to open PixInsight photo directly in Graxpert in 1 click and then import back processed image and background in PixInsight in 1 click.
This will open GraXpert usage in PixInsight for any interpolation method.
Unfortunatly, team was not able to fix a small issue related to command line.
https://github.com/Steffenhir/GraXpert/issues/118
We'll have to wait GraXpert 2.3.0...
Joel
Hi all,
For your information PreRelease v1.1.0 of GraXpert4PixInsight is now available here: https://github.com/AstroDeepSky/GraXpert4PixInsight/releases/tag/v1.1.0
In addition to standard AI mode processing, script allows integration with GraXpert UI to process any interpolation method (RBF, Splines, Splines, Kriging).
Basically from script, you can, in only one click, open photo in GraXpert. After manual processing and saving (using default file name and folder) you can import processed photo and background model again in only one click.
From PixInsight you can check, in one click, GraXpert UI parameters (interpolation method, grid...) and reprocess photo with a different smoothing and/or correction. Script will alert you when parameters are inconsistent (not enough grid points selected for instance).
Feel free to test and give feedback.
Works Great. I was able to export and import from the script. Great stuff Joel.
